855 cutting deck how to raise
m.daniels
04-04-2007 13:16:07
hi, hope you can help. i have just got hold of a 72" cutting deck for my 855 and after working out how it goes on the bottom of my tractor, and finding out that i am missing a couple of bits, i cant seem to work out how to raise and lower the deck. i thought it was something to do with the 3pl. can anyone help?
F-I-T
04-04-2007 16:03:12
 Re: 855 cutting deck how to raise in reply to m.daniels, 04-04-2007 13:16:07
third party image
Hi:
I have an 855 with a 72" belly deck. There were two methods provided to lift the deck. One was a mechanical bell crank that was linked via a turnbuckle to one of the three point lift arms. I THINK I remember that it attaches under the right hand side shield to the lift. Anyway, when you raise the three point, the bellcrank rotates this rockshaft bit, and the two lift arms that are connected to the deck lift it up. The position is controlled by the hanging stop, which is adjusted by turning the plastic crank at the forward left corner of the cover between your feet. This lift is what I have pictured.
I don't recall if this was standard or optional, as in "lift crank assembly, 1 required" or not, so there is a chance that your tractor did not have this option. Then again, maybe it was standard equipment. The rockshaft can be viewed under the chassis, located maybe a foot ahead of the rear axle, with two separate lift attach arms. You will attach the lifting loops to these arms and then to the deck.
The other version was an actual remote hydraulic cylinder used to move the rockshaft. This was acutated by a valve, probably the loader control valve, but maybe from an added power-beyond valve. Since I have only ever seen this item in the parts book, I cannot say better. Perhaps it was favored for heavy, front mounted attachments like a snowblower or a power broom.
Anyway, let me know if I can help with anything else.
Frank
m.daniels
04-05-2007 01:42:26
 Re: 855 cutting deck how to raise in reply to F-I-T, 04-04-2007 16:03:12
thanks for your help. the two lift arms are right at the top at the moment and will not lower down. do i need to switch between the tree point linkage and these or should both work at the same time.
F-I-T
04-05-2007 07:26:57
 Re: 855 cutting deck how to raise in reply to m.daniels, 04-05-2007 01:42:26
THey work at the same, meaning if you have a deck conne4dcted and a box blade on the three point hitch, and you drop the box blade, the deck will lower. NOW, the deck will only lower as far as that stop is cranked to, right there inside you left calf by that big decal. Maybe someone cranked yours all the way up so the arms cannot go down? So, raise the hitch, THEN turn the adjustment knob in the correct direction to get it to drop the arms.
I'll bet they're just being held up by the stop.
F-I-T
04-05-2007 07:28:28
 Re: 855 cutting deck how to raise in reply to F-I-T, 04-05-2007 07:26:57
I'm sleep walking this morning.
So raise the hitch, turn the crank to lower the arms, THEN LOWER THE HITCH, and then the arms should go down.
m.daniels
04-05-2007 09:15:30
 Re: 855 cutting deck how to raise in reply to F-I-T, 04-05-2007 07:28:28
done it. thanks for your help. the bars needed some weight on them to get them to go down. the hole thing works just fine now. thanks agian.
F-I-T
04-05-2007 10:37:04
 Re: 855 cutting deck how to raise in reply to m.daniels, 04-05-2007 09:15:30
Excellent!
