JD 4010 Question of the day for today....
TimS in Mo
04-04-2007 07:00:26
Is the transmission pump rebuildable or do you just put a new or remanufactured one in?
I looked on the JDPARTS website for a while but didn't see a seal kit for it.....
msb
04-04-2007 08:24:41
 Re: JD 4010 Question of the day for today.... in reply to TimS in Mo, 04-04-2007 07:00:26
I have on a few occasions seen the pump blow the paper gasket. Bob is dead on with his reply.
Bob
04-04-2007 08:53:02
 Re: JD 4010 Question of the day for today.... in reply to msb, 04-04-2007 08:24:41
Note the the pump BODY doesn't have a gasket.
There is a gasket between the transmission pump and the "manifold" that attaches to it.
Bob
04-04-2007 07:22:17
There's no seals used in that pump. If the housing and/or gears are worn; replace the pump.
Do you suspect problems with the pump?
Have you checked the flow from the transmission pump?
TimS in Mo
04-04-2007 08:42:47
 Re: JD 4010 Question of the day for today.... in reply to Bob, 04-04-2007 07:22:17
I am in the midst of checking the burnt tractor over for items that should be attended to while I am at it.
I am going to put a seal kit in the main pump and valve once I get it out and check it over good, I figured I might as well do the rear pump as the 3ph was a bit chattery at times and the front end loader wasn't as smooth as I would like.
I read in the service manual how to take the filter cover off and crank the tractor and check for sufficient flow, I will do that before I take the rockshaft housing off.
