1050 Tractor, Questions????
Mostly Green
04-03-2007 19:21:14
I saw a 1050 JD on a lot. Going to go look at it. Dealer says about an 85 model, 3 cyl diesel, 3 pt., 2 scv, etc.. What should I look for,what reputation does this tractor have and what would a range of values be. Thanks
jdemaris
04-04-2007 05:50:51
 Re: 1050 Tractor, Questions???? in reply to Mostly Green, 04-03-2007 19:21:14
We sold that series of tractors when they first came out - sometime early to mid 70s. I think the first was the 650 or 750. Never had a problem with any of them - very reliable, good starting, fuel efficient, etc. Just remember it's NOT a John Deere, it's a Japanese-built Yanmar with Deere green paint on it.
Mostly Green
04-04-2007 18:50:02
 Re: 1050 Tractor, Questions???? in reply to jdemaris, 04-04-2007 05:50:51
Thanks, Does the 1050 have a live PTO and Hydraulic System or does it require clutching to engage? How many Horse power and value???
jdemaris
04-05-2007 06:00:24
 Re: 1050 Tractor, Questions???? in reply to Mostly Green, 04-04-2007 18:50:02
It is rated at 33 PTO horsepower with a 105 cubic inch engine. Used the same size engine as the 950 but had a turbo added. As I recall - they never had independent PTOs - but maybe someone will correct me. Two stage clutches were used to allow live PTO use. Hydraulics were also live. Only trouble we ever had was with the first tractors shipped to the US - late 70s, maybe 77 or 78. Seems the trouble was due to the US diesel fuel having different specs. than Japanese fuel. So, we had to pull many injection pumps and shim them to change the timing. I worked for one of the first dealers to sell the Yanmar-Deere tractors - but I don't remember much about the newer models - e.g. the turbo 1650. The early tractors, e.g. 650, 750. 850, 950, and 1050 - were kind of crude or utilitarian Japanese machines - and did not come with independent PTO power, power brakes or even power-steering. I had to add a lot of US built power-steering kits. The Japanese tractors also use open-center hydraulics - different than any Deere ag. tractor at that time. Only Deere-built ag. tractor (that I recall) to use open-center hydraulics - since the 60s - are 1010,2010, and the German-built 820 series. Seems at some point in time though, the Japanese line did get some added ammenities. The Yanmar version of the 1050 - without the Deere name and paint was made available with a power-shift trans, built-in power-steering, independent PTO, etc.
