4050 head gasket
Pete1468
04-03-2007 19:15:08
I"ve got a 4050 with the 466 in it torn apart in my shop right now, it was using antifreeze and puking pudding out the blowby tube. I pulled the valve cover off and it was full of more pudding, the head is at a machine shop to be redone and crack checked. How common is a head gasket failure? The machine shop said he couldn"t find a crack but thought the head was warped. The owner did get the motor hot this winter as the thermastat must have stuck and it got hot on the feed wagon.
Pete1468
04-04-2007 15:19:45
 Re: 4050 head gasket in reply to Pete1468, 04-03-2007 19:15:08
I pulled a main bearing last night and it looked real good for 8000 some hours so back in it went. It didn't have any antifreeze in the oil pan when I drained the oil, it had been sitting for 5 days so it should have settled to the bottom by then. It looks like the antifreeze is leaking down around some of the lifter bores possibly like the head gasket had a problem, but it's so hard to tell. The machine shop said the head was warped .012, so I'm guessing that was the major problem but I'm going to check the water pump tonight.
G/MAN
04-05-2007 07:32:35
 Re: 4050 head gasket in reply to Pete1468, 04-04-2007 15:19:45
The next most likely leak point after the water pump is a liner o-ring. You won't be able to check until you have the head BACK on and the cooling system full, but you need to pressurize the cooling system and look for leakage around a liner or liners. The head gasket really is the LEAST likely cause for coolant getting into the oil.
G/MAN
04-04-2007 13:38:29
A head-gasket failure dumping water in the oil on a Deere 466? Not very common. More than likely it's the water pump. It's gear-driven off the front timing gears and if the weep hole is plugged, a leaking coolant-side seal will end up with cooling system pressure pushing coolant past the lip seal that seals oil on the back side. It's also not uncommon for a head to be a little "bent", particularly if the engine has been overheated. The head will need to be planed and rebuilt properly (valve protrusion up to specs, guides and seats replaced as needed, etc.) to restore good performance. You should also clamp down the liners evenly and check liner protrusion at the sealing flanges, and if there has been a bunch of coolant in the oil and it has ran that way for a while, I'd sure drop the pan and take a look at the bearings. Doesn't take much coolant contamination to start pitting the bearings out. I'm working on a 4560 with a similar issue of coolant in the oil and the water pump was leaking so slowly that the engine was able to keep the coolant boiled out of the oil - he was losing a couple gallons over two or three months. But even with a minimal amount of coolant in the oil, the bearings still showed a little damage. You'll also want to be sure to replace the cylinder head bolts, follow the instructions included with the head gasket kit PRECISELY for torquing the head - the old center-out sequence doesn't apply to these engines anymore - and make sure you don't get too much oil on the head bolts.
Mike M
04-04-2007 06:48:07
Are you also checking out that bottom end ? The antifreeze may be eating up the bearings !
matthies
04-03-2007 19:48:45
Did you happen to check the weep hole on the waterpump? If the weep hole is plugged the coolant will go past the seal on the drive of the pump and fill crankcase with coolant. First thing I always look at with a 50 series tractor. The weep hole is one the lower right side(alt. side)on the pump. chris
