301A remote hydraulic hookup
Tom Loos
04-03-2007 09:54:06
I would like to add a remote hydraulic hookup and valve to my 301A for a dump wagon. Can anyone give me some advice as to where I would tap in to do this? The wagon has one hydraulic line.
Thanks,
Tom
ET
04-03-2007 12:20:19
 Re: 301A remote hydraulic hookup in reply to Tom Loos, 04-03-2007 09:54:06
I just took a roadside mower off a 301. What Tom said is correct for the pressure line. The return was taped into the center of a large hex plug right under the valve that supplies presure, but it was only a 3/8" return fitting. So I think a better return would be to get the filter cover with the return fitting in it.
720 in pa
04-03-2007 11:20:16
below the right hand floor plate just to the rear and slightly above the tranny filter you will see a three bolt valve with a line going in the front.to the rear of that valve in line with that line there should be a plug which is main pump pressure
Tom Loos
04-03-2007 11:40:57
 Re: 301A remote hydraulic hookup in reply to 720 in pa, 04-03-2007 11:20:16
Thanks for the reply...
What about the return line? I think this is an open-center/closed-center question too. If the dump trailer has just one hydraulic line, I assume pressure and bleed are handled by the control valve. The valve should have a pressure input, a pressure output and a return line right? Where would I plumb the return line from the valve back into the tractor? Obviously I'm not familiar with this stuff - thanks for the help.
Tom
