JD 4010 question of the day....
TimS in Mo
04-03-2007 07:23:25
How do you get the dampener on the forward end of the crankshaft off?
The fire damaged the rubber in the dampener, I need to get it off. I pulled the fuel tank, hydraulic oil cooler, radiator, and the crankshaft to hydraulic pump coupler.
I assume I need to use a puller on this, but there isn't enough clearance between the end of the crank and the end of the hydraulic pump for my puller.
I most likely will drop the front axle off and pull the hydraulic pump and at least put a seal kit in it while I've got the tractor tore down this far.
DaveH IA
04-03-2007 09:31:29
 Re: JD 4010 question of the day.... in reply to TimS in Mo, 04-03-2007 07:23:25
get you a 3/4 in plate 3 in wide and 1 ft long Drill 2 holes to match the pump drive holes--(use the drive yoke to lay out the holes)in one end---remove the center bolt and washer-- put the bolt back in as far as it will go --bolt the plate on the pump drive holes (3/8 bolts) and back out the center bolt aginst the plate
Bob
04-03-2007 08:06:30
Remove the bolt that retains the damper to the crankshaft.
Bolt an appropriate puller to the two bolt holes in the damper that drive the hydraulic pump.
(Use an approprate "puller plate" on the snout of the crankshaft so as to protect it from the point on the puller screw.)
TimS in Mo
04-03-2007 07:24:20
Here is a link to my blog with pictures of the old burnt out 4010 as we rebuild it and the new ( bought from Rfox, thanks Randy ) 4010 as we spruce it up a bit.
www.twstanley66.blogspot.com
TimS in Mo
04-03-2007 10:19:53
 Re: JD 4010 question of the day.... in reply to TimS in Mo, 04-03-2007 07:24:20
Brilliant ideas, thanks so much!
You guys are the best!
Bob
04-03-2007 10:31:29
 Re: JD 4010 question of the day.... in reply to TimS in Mo, 04-03-2007 10:19:53
Nothing "brilliant" about it just "BTDT"!
