And now you know why I don't recommend a liner if the tank has no holes that cannot be solder repaired. It's just too easy to have that membrane let go. Some people see dirt and rust and elect to "stick it place" using a liner, then trap small droplets of water in the trash, and can actually develop a rust-through under the liner. Others have delamination and then have more problems that they started with concerning floating chunks of plasticized latex. One of the likely problems was that you did not etch prep the steel to tooth it up so the membrane had something to stick to. Normally one would use Phosphoric Acid to etch the surface AND to convert any remaining red rust to inert black oxide. Look on the label and see if your particular liner product is soluble using MEK or Acetone, etc. If so, you could "melt" it out, re-clean the tank, and if it does not have any leaks, phosphate flash it and use it. I have not lined a tank in years as they are easier for me to repair and clean, plus I hear more "liner-gone-bad" stories than I ever hear of tanks that cannot be soldered. "Red Kote" is a good choice if you must line. It is soluble in MEK, so you can remove it easily if you are not happy with the installation. Frank
