JD 3010 smoking
bigdiesel
04-02-2007 15:16:57
bought a 3010 diesel, it runs rough and smokes white. tried turning the inj. pump and it does nothing, no change. I cracked each injector and and it misses badly when i do that, so its not the injectors. anyone have some ideas, thanks a bunch
wilamayb
04-03-2007 04:17:49
 Re: JD 3010 smoking in reply to bigdiesel, 04-02-2007 15:16:57
Since it sounds like is started acting up suddenly I would look for either a hole in a piston liner, cracked cylinder head or perhaps a blown head gasket. Do you keep the antifreeze fresh with coolant conditioner?? There is really no way to prove that water is entering combustion unless you drain the radiator and block and do a test run. It will be fine to run the engine for 30 seconds or a minute without water to see if it clears up. If so you have found the problem. My bets are on piston liners. Keep us informed
Dairy Farmer in WI
04-02-2007 18:44:24
white smoke usually means it's burning anti-freeze. you might have a bad head gasket.
wolfman
04-02-2007 15:47:39
I've had a 3010D for about 20 years-it always smoked some, had blow-by out the breather, was always sick for power. Last year I gave it a new JD motor kit. Now no smoke or blow-by but even less power. Rates right even with my super C for power- well not quite as peppy as the C.
