High Oil Pressure
n29we
04-02-2007 13:13:39
Hi All - I've got a 47 "M" that is running at very high oil pressure. The oil has been changed and is at the right level. I have ordered a replacement plate for the oil filter canister because it's missing. Supposedly it doesn't allow the filter to work correctly but could that cause the problem? The oil pressure gauge has been replaced with a known good gauge. Still high! What else could it be? Any help would be great!!! JimO
Andy Motteberg
04-03-2007 14:57:37
 Re: High Oil Pressure in reply to n29we, 04-02-2007 13:13:39
oil pressure is good, its better higher than lower.
Henry M
04-03-2007 13:08:59
Jim O
My parts manual for the 420 sows the oil pressure relief machanism mounted on the side fo the oil pump like posted earlier
Lee S
04-03-2007 08:07:58
Jm - I suggest you check that the pressure regulating piston (valve) is loose. My MT was pegging the guage and I found that the piston was stuck in place. You can check by inserting a magnetic on a rod and seeing if you can fish it out. I had to ream mine out which solved the problem. - Lee
jd51mt
04-03-2007 05:33:39
Jim,
I think what Henry is talking about is the Pressure Regulating Mechanism. It is on the side of the oil pump. It might have a broken spring (L 752 T) or missing the washers(L 4232 T) . It should have two or three washers to make the oil pressure around 30 lbs. The Pressure Regulating Piston (L 4233 T) might need to be replaced.
MIke
Henry M
04-02-2007 18:34:48
Something is not adding up. There is sposed to be a pressure relief mechanism that bypasses the oil to control the presure - - I think.
n29we
04-03-2007 03:28:28
 Re: High Oil Pressure in reply to Henry M, 04-02-2007 18:34:48
DO you have any more info on that?? I can't find anything in the manuals. Thanks - JimO
Glen in TX
04-02-2007 13:38:47
Check the filter assembly over well again and hope you find problems there and not a spun bearing blocking oil galleys causing higher pressure.
n29we
04-02-2007 13:31:55
I guess the fact that the gauge pegs on the high side it concerns me. I agree that high rather than low is good but it's still strange. JimO
molinebob
04-02-2007 13:16:46
I guess I have never heard of any body complain of to high of oil pressure. I think the higher the better.
