JD 4010 question ( like always )
TimS in Mo
04-02-2007 10:59:22
Ok, working on the new to us 4010, its a 1963 diesel model.
Periodically the engine revs up a bit, I can blip the foot throttle and it comes back down, or it will drop back down on its own. It also doesn't hold a real stable rpm via the tach when set with the hand throttle..
Any ideas?
Seems to me most likely the governor weights/springs in the injection pump?
( Just guessing, never been into one of those pumps but I have read a bit on here about them. )
I recovered the burned out tractor yesterday using the new 4010.
First I used the 148 loader on the new one to pick up the 148 loader on the old one and hauled it back home and set it off to the side.
Next, used a chain to drag the burned one down hill to a flat piece of ground so I could back up to it.
I then chained the quick hitch to the front loader mounts of the burned one, picked up the front end a bit with the 3ph, and drove it on up the hill in the pasture to the gate, down across the road and into our drive, and into the barn where we unhooked it.
Only problem I had was with it chained up that way it was a bit tough to steer, haha.
The old burned up one is up on blocks in the barn, starting the process of stripping off the bad stuff and replacing it with good.
msb
04-02-2007 18:39:04
 Re: JD 4010 question ( like always ) in reply to TimS in Mo, 04-02-2007 10:59:22
Its past time to have the injection pump rebuilt. Ask the repair station to install the newer style governor weight retainer that no longer has the plastic seal in it. It won't affect the performance and will end having the pump rebuilt because of the plastic going to pieces.Also ask them how to time the engine. That will depend on where the timing mark is scribed on the new weight retainer. They are not maked when new and it takes special equipment to properly mark them. Before reinstalling the pump check to see that the return line is not plugged with small bits of plastic.
720 in pa
04-02-2007 11:07:23
sounds like the govenor ring is bad in your injection pump. to repair you will need to remove pump. they have a plastic or synthetic ring inside the pump which drives the governorand it is probably bad
jd40an
04-02-2007 11:03:30
Sounds like it's time to have the injection pump rebuilt,& no, they don't get any better if you keep on using it that way!
