2640 PTO question
steelerfan4460
04-02-2007 00:14:03
hi i have just bought a 1980 model 2640 tractor. 2800 actual hours,it's a nice tight little tractor. only one problem,it's straight 540 and i need 1000. i have heard they come with both setups,so im wondering if i can somehow make it both shafts or can i run an adapter for it? im not sure if it will make 1000 with an adapter though. any help would be much appreciated. as i said,i like the tractor,but if i cant make it both shafts ill have to get something else. thanks in advance.
Mike M
04-02-2007 05:47:30
 Re: 2640 PTO question in reply to steelerfan4460, 04-02-2007 00:14:03
Saw it advertised here before there is a gear box made to do that. I think they have models to go both ways.
pjbrown
04-02-2007 05:23:56
I think they only put the 1000 on tractors over 75 HP. Does your have a snap ring that holds the shaft in??
cannonball
04-02-2007 04:07:43
JD parts shows both shafts on serial number 341000 and above without reverser... know some 2130's were same way..
MAY GOD BLESS THE USA
MSM
04-02-2007 01:26:04
They came 540, and very very few came with 1000 only, not both. If you are real lucky,you might find a 1000 rpm tractor in a salvage yard and swap the gearing and shaft.What are you running that you need a 1000 shaft?
