4020 sound gaurd cab 140099994272
Nylon
04-01-2007 19:27:50
140099994272
Nice looking tractor...almost makes me want to by it and sell mine but I can't handle another project at the moment. How on earth do you move the synchro shift to the right side console and make it all work smooth?
Nylon
04-02-2007 09:38:25
 Re: 4020 sound gaurd cab 140099994272 in reply to Nylon, 04-01-2007 19:27:50
Ohhh another question. (4020) What color is the dash supposed to be. I have seen them all black, all green, black upper dash with green lower dash and green upper dash with black lower. What is the proper color scheme.
Thanks,
John
JDBert
04-02-2007 06:38:19
third party image
He also took the dash out and used the newer dash. We used a cab with no dash or fire wall and just "added" the cab to the tractor. We left the pedals/shifter/dash alone, so if we ever want to return it to stock we can. This one IF you ever wanted to put it back to stock you'd have to go hunt up a bunch of parts to get it there. Its about 5 miles away from me- I should go look at it and see how he did stuff compared to how we did it.
Nylon
04-02-2007 09:33:53
 Re: 4020 sound gaurd cab 140099994272 in reply to JDBert, 04-02-2007 06:38:19
I hope you have this tractor parked in garage and out of sight....I would end up just looking at it all day and never get anything done. What a beauty specimen. On the e bay tractor it must have been a trick to get linkages run from new shifter location to forks. That is what I was wondering as to how smooth it could be shifted....I have enough trouble with it on dash the way it is. Anyway what a great tractor you have there...turbodiesel no less:}
Bob
04-02-2007 17:56:41
 Re: 4020 sound gaurd cab 140099994272 in reply to Nylon, 04-02-2007 09:33:53
The Soundgard Body has shift linkages that connected to the shifter shafts on the tractor it originally came off of. The shifter shafts are more or less in the same place on the 4020 so it would be possible to connect them up with only minimal "mods".
Tx Jim
04-02-2007 04:43:05
Nylon,as Bob stated if SGB was built originally for a syncro-range tranns. it would be relatively easy. Acutually to mount SGB on late model 4020 shouldn't be that difficult once rear mounts were fabricated because 4020's had no holes in axle housings for factory mounts. Years ago I worked on a 4430 that came from factory open station(no holes in axle hous.) but had SGB added. Last time I looked at Ebay this tractor was cheap for what used SGB will bring from bone yard. Tx Jim
Bob
04-01-2007 19:30:57
"How on earth do you move the synchro shift to the right side console and make it all work smooth? "
Actually; it pretty easy. All's Deere needed was a couple of extra shift rods and two "bellcranks"!
