How can I by pass a GX345 pto
Randy G.
04-01-2007 18:43:19
How can I by pass a 2005 GX345 pto so when I back up the mower stays on? Just got it and mowed today. What a pain in the!@#$. Please offer a solution. Thanks guys!! Randy G.
Jon Hurley
04-04-2007 11:21:22
 Re: How can I by pass a GX345 pto in reply to Randy G., 04-01-2007 18:43:19
on my GX255, there is a switch on the right hand side, at the back of the tractor on the transmission. The reverse pedal has some linkage that pushes on this switch. I disconnected the harness from the switch. Then I took a 2 or 3" piece of wire and put a male spade connector on each end of the wire. I then put this jumper in the connector that I took off of the switch. Just like that, it was "fixed". Hope your is similar.
ram ranch
04-01-2007 20:31:51
under the right floor borded, where you directional peddles are. hidden in the frame is the adjustment switch for the mower clutch. Two bolts hold it in place, they are on a slide to change the sensativity of the switch. If I remember right I just adjusted mine so it would not work. This was over a year and a half ago, so feel up around there and you can figure it out. I'll check later if you have any troubles.
Jon Hurley
04-04-2007 04:53:35
 Re: How can I by pass a GX345 pto in reply to ram ranch, 04-01-2007 20:31:51
I have a GX255, I think I just unhooked the electrical connector from the switch, and put a jumper connected the two sides together. I will check when I get home this evening.
