Hey, John T
Bobl1958
04-01-2007 18:33:49
Just wondering if on that 720 diesel fuel gauge I get power to the small post when I depress the push button, should I get power out the other terminal, which goes to the sending unit? I am trying to see if the gauge works. The gauge needle is not stuck in the gauge. When I push the button, my test light shows power to the small terminal, which comes from the button, but no power coming out of the other terminal to the sending unit. What are your thoughts? Thanks again for your help. Bob
John T PS
04-02-2007 05:41:57
 Re: Hey, John T in reply to Bobl1958, 04-01-2007 18:33:49
Bob, If the needle deflects when you momentarily flash/bump the gauges output to frame ground with voltage on its input but does NUTTIN with the sender attached regardless of float level,,,,, ,,,Often the problem is the sender isnt getting a good ground return curent path via the tank mounting to the frame or the sender to the tank or else the grounding tab on the sender isnt well grounded OR ELSE the senders variable slider resistor wire has broke open (typical).
Try to use a jumper wire to ground the sender or any grounding tab on it.
John T
John T
04-01-2007 20:13:54
Bob, Im not exactly familiar with your particular gauge buttttt ttttt basically they are a passive series device. You put voltage on one end and a load (the senders variable resistance) on the other which allows current to flow through them, then to the sender, then frame ground sooooo oo THEY CANT BE AN OPEN CIRCUIT. Maybe you ought to remove any wires on the gauge terminals and measure its resistance/continuity to insure ITS NOT AN OPEN CIRCUIT.
HOWEVER if shes wired up and connected to the sender and its good, I wouldnt expect much voltage on the gauges output, cuz that point is basically tied to frame ground (resistance varies relative to float level) via the senders resistance. Its like trying to read voltage on the ignition coils output when the points are closed NONES PRESENT THEN cuz the closed points take that point to ground.
On many gauges I test to see if its a gauge or sender problem by applying voltage to the gauge (should be present when ignition is turned on) then momentarily flash ground the output n see if the needle full deflects?? It should cuz current flow through it is what moves the needle and when you dead ground the output thats taking the place of the senders variable resistance. If the needle dont even flinch then I suspect its a bad gauge versus the sender and to verify that measure the gauges resistance to see if its an open circuit (means bad gauge). Another gauge n sender test is to hook it all up with the sender out of the tank so you can raise n lower the float n see how the needle reacts.
NOTE is this on a 720 diesel with the push switch type gauge?? Those get voltage from the genny ONLy when running but otherwise you have to push the switch so they get voltage from the ammeter/battery.
NOTE the gauge has to be matched with the correct sender otherwise the resistances dont match up ya know.
If you momentarily spark/bump/flash the gauges output to ground with voltage on its input she sure ought to cause the needle to deflect !!!!!
John T
Bobl1958
04-02-2007 07:13:14
 Re: Hey, John T in reply to John T, 04-01-2007 20:13:54
I"ll give it a whirl tonight and see what I get. I"ll keep you posted. Thanks once again-Bob
