70d flywheel issues
stn.tn.
04-01-2007 18:14:49
I have a 70d with a bad flywheel and slight wear on the crank (.006). I have been told that a taper lock is the way to go. My flywheel #is F1913R. If I use a taper lock will my cover still fit over it o.k. and what would be a good price and where.
Earl-IL
04-01-2007 19:38:48
 Re: 70d flywheel issues in reply to stn.tn., 04-01-2007 18:14:49
With a little machining it will all go under the cover.The man that manufactures the flywheel in Jonesborough, TN. Will tell you how. phone is 423-753-5738 Best place to buy.
stn.tn.
04-02-2007 02:53:09
 Re: 70d flywheel issues in reply to Earl-IL, 04-01-2007 19:38:48
Thanks Earl-IL,I appreciate the info and #,This is only 1 hour away from me,ain't it a small world.
mark ace
04-01-2007 18:34:04
I HAVE ONE ON A 70D AND IT HIT THE COVER, I TOOK A 16' PICKUP RIM AND SET IT THE PRESS, PUT THE COVER OVER IT AND USED A ROUND DRUM THE SIZE OF THE CENTER CIRCLE IN THE MIDDLE AND PRESSED THE COVER OUT ENOUGH TO CLEAR THE FLYWHEEL HUB. IT LOOKS GOOD & DONT HIT. I PAID $650 FOR THE FLYWHEEL A FEW YEARS AGO BUT HERD YOU CAN SPEND ABOUT $800 NOW
stn.tn.
04-01-2007 18:59:20
 Re: 70d flywheel issues in reply to mark ace, 04-01-2007 18:34:04
THANKS MARK ACE, I PROBABLY WILL GO THE TAPER LOCK WAY. NEW ENGINE AND NEW PONY,WHY NOT GO A LITTLE MORE EXPENSE. THANKS
