2840 Steering
Bob 666 A
04-01-2007 17:02:35
Our 2840 streering is tight when turning to the left but loose to the right. When the steering wheel is turned to tehe left the linkage moves immediately. When turning the steering wheel to the right it moves up about 1/4 inch only then does the tie rods move. I know there is a problem in the steering column but does anyone know what it might be. This is our planting tractor and we have to eliminate any excuse for crooked rows. Thanks.
Tx Jim
04-02-2007 11:51:55
 Re: 2840 Steering in reply to Bob 666 A, 04-01-2007 17:02:35
It's normal for steering wheel to raise and lower a small amount while turning from side/side. Excessive movement/looseness means something(probably valves)inside steering valve housing needs attention. I can't remember but doesn't 2840 have two steering cylinders? Tx Jim
Bob 666 A
04-02-2007 15:51:09
 Re: 2840 Steering in reply to Tx Jim, 04-02-2007 11:51:55
trying to remember, the steering wheel shaft is almost verticle and the linkage comes out under the tractor and connects to a tie rod that runs along the left side of the motor to the front where it connects to the front linkage. This is a new one on me.
