3020 Wide Front Blues
SproutW
04-01-2007 15:52:54
Have a 3020 wide front that is giving me fits. The wide front is factory John Deere and not after market. Every once in a while the right side spindle seems to spin and causes the front end to be out of alignment. Took the top part of the spindle apart and didn't see anything obvious. However, the piece that connects the spindle to the tie rod is elevated about 3/8 of an inch above the spindle support. Anyone had this same problem?
SproutW
04-03-2007 14:04:20
 Re: 3020 Wide Front Blues in reply to SproutW, 04-01-2007 15:52:54
Thanks everyone for your posts. MSB I wanted you to know you hit the hammer on the head. The welds to the spindle (at the bottom) were broken. The spindle did not break clean and had jags holding it together when pressure was applied. Thanks again and now it's time to order parts.
msb
04-01-2007 19:44:10
Look at the bottom of the spindle. That is where it is welded and sometimes the weld breaks Have tried to heat & twist them back to where they should be.Haven't budged one yet. Not only is it welded, but the thing is assembled under tremendous pressure. Only solution that I have found is to buy a new spindle. Since yours has the gap, you might try pushing the shaft out in a press.
Mike w J
04-01-2007 17:29:08
Is the spindle shaft broke half way down the tube They don't break straight so it would have like a cam action that would raise the tie rod arm . When the wheel turns out of alighnment does it correct itself when you back up ? Jack it up see if the wheel and spindle drops down out of the tube.
Doug in IL
04-01-2007 17:21:51
The splined shaft may be twisted. I have seen that happen before.
SproutW
04-01-2007 16:28:56
third party image
Another
Glen in TX
04-01-2007 16:27:00
The wide front housing has replaceable bronze bushings in it the spindle shaft rides on. Those bushings and spindles can get worn. The splines on top of shaft can get worn but it's usually the cast tie rod arms that get worn or cracked. Check the cast arm for cracks or wear and that splines are aligned right. Are lower ends of spindles worn too or was a front loader on it? All those parts are available new from JD, A&I and other aftermarket vendors.
SproutW
04-01-2007 16:33:40
 Re: 3020 Wide Front Blues in reply to Glen in TX, 04-01-2007 16:27:00
The tractor does have a loader on it. The front end was bought new 4 years ago. My father tells me he did drop the front end into a tile hole an screwed things up. I just don't see any obvious damage, but I cannot explain why a gap exsists on the one side of the spindle but the other side has no gap. You can see the gap in the pictures.
Glen in TX
04-01-2007 16:42:48
 Re: 3020 Wide Front Blues in reply to SproutW, 04-01-2007 16:33:40
Yeah I could see the gap. Better pull it apart now and not be driving it at any high speeds it may be about to come apart on you! It's either worn on bottom side or breaking about to twist off or someone welded it back together and weld breaking or too long now? The arm won't go all the way down on the spline end of shaft unless worn out too much.
SproutW
04-01-2007 16:18:26
third party image
Here are some pictures
