41 JD B Camshaft Locking Plate
Ted in SD
04-01-2007 15:11:12
In my manual it shows a locking plate for the bolts on the camshaft, but I have lock washers on mine. Just wondering if that is right or I messed things up somewhere along the line, and if lock washers will work or if I will need the lockin plate??
Thanks
mattd
04-01-2007 15:26:24
 Re: 41 JD B Camshaft Locking Plate in reply to Ted in SD, 04-01-2007 15:11:12
clean your threads up and use blue loctite. lock washers should not be used in the internal parts of a motor. and those plates arent needed if you use loctite.
