Governor mounted pump question
Kurt_JDB
04-01-2007 12:50:24
I picked up a used live hydraulic pump that I would like to put on my "52 B tractor. I just got done tearing it down, and I find that the pump body and the cover are scored up pretty good where the sides of the drive gear and the follower ride. Is the pump toast? Is there any repair that can be done to these parts?
Kurt
John Didde
04-02-2007 06:33:03
 Re: Governor mounted pump question in reply to Kurt_JDB, 04-01-2007 12:50:24
I have parts for the pump, let me know what you need I will help you out. Go to website below.
Link
Thanks John
Glen in TX
04-01-2007 16:35:35
Kurt, Most of the I&T manuals give you some wear tolerance specs to go by and if not more are in the JD SM2011 Hydraulics service manual. If you just some need some wear specs to go by email me. You'll probably have to make new shafts and bushings for the gears too. Like Franks said with lower pressure on these pumps tiny scores are not much problem.
Kurt_JDB
04-01-2007 17:05:03
 Re: Governor mounted pump question in reply to Glen in TX, 04-01-2007 16:35:35
Thanks for the offer, Glen. I do already have both the IT book and SM2011. I guess I'm trying to get a feel for how much scoring I can live with. I'm assuming the major problem would be lower pressure rather than an external leak, as the scoring would allow the fluid to "short circuit" I'm going to study on it some more.
Kurt
Glen in TX
04-01-2007 17:43:47
 Re: Governor mounted pump question in reply to Kurt_JDB, 04-01-2007 17:05:03
That's it Kurt how much noise and lower pressure you can live with. It doesn't take much scoring on newer high pressure aluminum body pumps to lower them a lot but you are working with less than half that kind of pressure and volume.
F-I-T
04-01-2007 16:27:16
third party image
Kurt:
If it is a JD type pump where the covers are flat and not recessed, you can regrind them flat to remove the scars, then lap on a flat plate so that everything is dead flat. If you can remove the drive axle form the one gear, you grind the thickness of the gears a like amount, placing a shim under them equal to the side play that is specified, and all will be fresh to factory. You can use half the shim thickness and face one of the body side surfaces and the gears sides, then flip and add the full shim amount under the gears so as to do the other side at that time. Repairing the body is a pretty tough task without some welding up and re-machining on a stable machine like a jig bore, but if the scarring is not too bad, it might still keep up and provide the needed flow even with a little leak-by. You�re only looking to get 900 or so psi for Powr-Trol application, which is pretty forgiving.
Frank
Kurt_JDB
04-01-2007 16:59:16
 Re: Governor mounted pump question in reply to F-I-T, 04-01-2007 16:27:16
Frank, It is a JD pump, same one as in the parts book page you posted. The drive gear has made a recess in the pump body, mayby .01 inch or more. I think I could get them ground flat if I can get the follower axel out. I am thinking of drilling and tapping the end of the axel so I have something to pull against.
The drive gear and its axel are all one piece, so it would be a trick to grind it. The sides of the gears aren"t so bad and they mic out pretty close to spec. So if It dosn"t set me back too much to have the rest ground and lapped, I"ll have a go at it.
I"ll check with JD next week and see if they still carry the seals.
Kurt
