jd b gas tank
630man
04-01-2007 07:21:55
Does anybody have any ideas on what I should use to clean out my gas tank. I drained out the old gas it was like varnish and now sludge type stuff is dripping out. and ideas would be great. thanks in advance
John
CLTX
04-01-2007 16:12:47
 Re: jd b gas tank in reply to 630man, 04-01-2007 07:21:55
Can you still get muratic acid locally? I know that the EPA was coming down on using acid for marine use several years ago. I used to use muratic to boil out keel coolers on a steel shrimp boat, and it got to be difficult to find.
Pete in MD
04-01-2007 10:32:53
The part of the tank that doesn't have varish is probably rusty. If it is, get a gallon of Muriatic acid at a hardware store and mix it 50/50 with water in a bucket. Put a pipe plug in the outlet and pour in the 50/50 mix. Put the gas cap on and slosh the mix around for a few minutes. Drain the tank and flush well with water for several minutes. Take out the pipe plug and shove a shop vac hose in the filler neck so that it's blowing air into the tank and water/air out the outlet on the bottom of the tank until the tank is dry. Leave the tank out in the sun to make sure all moisture is evaporated. Inspect the inside with a small mirror and it should be bright medal. If not, repeat the procedure. As soon as the tank is clean and dry, coat the inside with Kreem or a similar product. I did this with my B tank 3 years ago and have had no problems since then.
jdhbag
04-01-2007 09:30:13
Try Marine Clean from POR 15. I had one like that and it worked wonders. Or u can go to your local grocery store and get a bottle of Greased Lightning that works pretty good also.
DW
04-01-2007 07:45:24
Try "Gumout" brand carb and choke cleaner. Unless they changed their formula, it used to work very well to dissolve that gooey old varnish.
