GP skeleton steel ?
Nebraska Cowman
04-01-2007 03:40:48
I listed a set of steel on ebay after being told it fits GP wide tread. This morning I get an email saying it ain"t so. The lugs are part number A684R on F&H 47 inch wheels with hub casting number HA981C So what are your thoughts? Oh yeah it"s Item number: 320098703939
Duane Larson
04-01-2007 08:34:37
 Re: GP skeleton steel ? in reply to Nebraska Cowman, 04-01-2007 03:40:48
Nebraska Cowman,
I think your skeleton wheels listed on eBay are for a F20 Farmall, indicated both by the casting number and size. They came in both 42" and 47" sizes. I'm not sure about your lugs as the ones I have seen are 32871D. 40 JD G has the correct info for skeleton GPWT wheels. Allis Chalmers WC skeleton wheels were 40", and UC wheels were 42".
While the center hubs for the JD, IHC, and AC wheels are similar (but visually different in detail), the bolt ring diameter for the JD wheels is 6 3/4" and the diameter for the AC and IHC wheels is 6 7/8", all with 6 - 5/8" holes. So, to make IHC and AC wheels fit a Deere the holes need to be enlarged to 3/4".
All that being said, I have only seen one set of the wheels you have - on an unrestored F20 - so the Farmall F20 folks should be made aware of them.
Nebraska Cowman
04-01-2007 14:45:44
 Re: GP skeleton steel ? in reply to Duane Larson, 04-01-2007 08:34:37
Humm, so I have Farmall wheels with John Deere A lugs? Now what do I do?
40 JD G
04-01-2007 06:24:19
I saw your wheels a couple days ago. They will fit a GPWT, but are not correct. I think your wheels were used on the F-20's and the Allis WC's. The GPs had 46 or 43 1/2 inch wheels. The casting number is HA503A. Duane Larson will probly be on here he knows a lot more than I do.
