4020 wont shut off
J Brock
03-31-2007 16:33:42
Helping out an uncle by changing the oil on his 4020 and when I pulled it up to the shop I shut the key off and it was still running. I had to end up unhooking a fuel line. Here is what I know.
1. 1967 4020 Diesel
2. It has a fairly new looking Alternator
3. 2 12 volt batteries both hooked up neg-ground
My question is how could I have shut it off with the wires going into key switch? If I knew the answer to this that would tell me what terminals on switch should have continuity with the key off and in turn telling me if its a bad switch or not
Nathan (SD)
04-01-2007 11:26:08
 Re: 4020 wont shut off in reply to J Brock, 03-31-2007 16:33:42
Better check with your uncle before you attempt that oil change. He maybe wants to be around for that.
Handsome Jim
04-01-2007 15:54:00
 Re: 4020 wont shut off in reply to Nathan (SD), 04-01-2007 11:26:08
I'll second that.
justin dickmann
03-31-2007 17:05:34
if it is a diesel you need to pull the knob out on the throttle and lift up then rember to turn the key off so you don"t drain tha battery.
msb
03-31-2007 20:11:04
 Re: 4020 wont shut off in reply to justin dickmann, 03-31-2007 17:05:34
YEP. Pull out the throttle knob and push it all the way up. Side console models are the only Deere diesels of that vintage that shut off with the key. Germans refused to install a key shut off on the 4430s and up equipped with German Bosch injection pumps even though Deere engineers wanted the feature on the then new 30 series.
justanothercase
03-31-2007 16:57:20
im not real familiar with a 4020. check for bare wires that may be shorting somewhere between the coil and the switch or just replace the wire with a jumper wire for now to see if it cures your problem. then fix it the right way. good luck.
