720 diesel electrical question
Bobl1958
03-31-2007 13:19:09
Can anyone tell me if a two post switch can be used on the fuel gauge push button switch? The original switch, part #AF2171R has three posts. One for the sending unit, one for a black wire to the generator, and one for power. Could any two wires be wired together on one post, and the remaining on the other post, or do I need to get a three prong switch? Thanks- Bob
Bobl1958
04-01-2007 07:37:45
 Re: 720 diesel electrical question in reply to Bobl1958, 03-31-2007 13:19:09
Thanks a million guys. I will do it right. It appears the switch is available. Thanks again for your information. Bob
John T
03-31-2007 15:57:56
Bob, To work as it came originally from the factory, it requires a Single Pole Double Throw switch, which is why 3 terminals are required. When running the genny provides voltage but when not if you depress the switch it gets voltage from the battery.
If you just wanna use a Single Pole Single Throw 2 terminal push switch you could choose say just the battery so you ALWAYS have to depress it to work, or if you chose the gennys output as the voltage source and still have to depress it to work it would only work when shes running. If you used an On/Off Toggle switch (NOT any push button) and fed it from the battery it would drain the batery when setting if you didnt turn it off. On gas engines they are fed off an ignition switch so they only work when ON but on that diesel you need a different set up.
Clear as mud??? The correct switch shouldnt be that hard to get or expensive if you wanna keep her original versus a jury rig. Or go to Rat Shack and get a push type momentary spring return Single Pole Double Throw 3 terminal switch.
John T
WeirdDeere
03-31-2007 15:42:50
It is a bit complicated to explain without the switch in front of me, but to make the gauge and push button to work correctly, you need the correct three prong switch.
Brandon
