D water valve question
Farmboy169
03-31-2007 07:49:38
Good morning guys. This may sound like a dumb question but, I heard the other day that if you have a water valve (and plan to use it) on your tractor, you can only use straight water in the radiator, not the typical 50/50 blend with antifreeze. Is this true or is somebody yanking my chain? Thank you guys once again for your input.
95CS
03-31-2007 09:16:09
 Re: D water valve question in reply to Farmboy169, 03-31-2007 07:49:38
No, they're not yanking your chain. Ethylene glycol anti-freeze isn't combustible, does bad things to carburetors, and just isn't a substance you want anywhere in the engine besides the water jackets. The water injection feature was only used when pulling hard on distillate or kerosene, to prevent detonation or more accurately, pre-ignition. If you're not planning to ever run your "D" on distillate, I'd suggest you solder the valve closed, so that anti-freeze can't get into the carburetor and engine.
Glen in TX
03-31-2007 09:57:34
 Re: D water valve question in reply to 95CS, 03-31-2007 09:16:09
The valve itself is worth a bit on the market to solder shut. Why not just not solder shut the cheap copper tube between valve and block fitting if you need the authentic look?
95CS
03-31-2007 10:36:56
 Re: D water valve question in reply to Glen in TX, 03-31-2007 09:57:34
That's what I meant, my bad for not saying the tube.
Glen in TX
04-01-2007 07:56:22
 Re: D water valve question in reply to 95CS, 03-31-2007 10:36:56
I figured that's what you meant but he might not have knew. Just kind of shocking sometimes what water valves are bringing now and way too many of them got a pipe plug on block and carb later getting tossed in a scrap pile. I did find a valve hard brazed shut once on one end and never understood why someone would do that and it had ruined the valve. You are right about them not wanting to try to burn antifreeze causing more problems. I doubt newer Champion plugs would take much of that and be dead on the spot.
Glen in TX
03-31-2007 08:08:29
Why waste antifreeze when you are going to burn it up? Yes, they were meant to be ran on straight water and many with JDs thermo-siphon system actually cooled better that way. Always heard when you ran a D on long days you hauled almost as much water to the fields as fuel. The water keeps engine from pinging (pre-detonation) when running on kerosene or distillate fuels. You drained them every night in cold weather and that's why many have the block drain plugs messed up or threads torn out. Sometimes you find a pipe threaded in block drain with a gate valve on there for that reason.
