3020 Transmission Disconnect Lever
TomNTex
03-31-2007 04:53:33
I've got a 64 model 3020 PwrSft LP. I've had this tractor about 2 years and have never been able to move the trans disconnect lever on the left side of the tractor. I don't guess I've needed it so far as the tractor has always started rather easy. Just wondering if there is a locking device holding this in or perhaps just some linkage that needs adjusted or lubricated from years of not being used. I understand this aids the tractor in starting by disconnecting the trans load from the engine. How important is the functionality of the lever? Say it doesn't have a lock and is just froze up. How to go about getting it freed?
Thanks
Tom
msb
03-31-2007 08:39:34
 Re: 3020 Transmission Disconnect Lever in reply to TomNTex, 03-31-2007 04:53:33
Its probably rusted tight where it goes through the side on the tractor. Try soaking it with some penetrtating oil for a while. Remove the kick panel and squirt some inside on the lever shaft too.Can you pull out the release knob? It could be a part of the problem.
