Clutch handle pivot hole dimension
pa_popper
03-30-2007 18:08:32
The pivot pin hole on my 51 G clutch handle is worn oblong causing a lot of slop. I want to weld up the hole, then drill it out to add the deere bushing and new pivot pin. What size should the hole be drilled to accept the new stock bushing?
dds-inc
03-30-2007 20:02:59
 Re: Clutch handle pivot hole dimension in reply to pa_popper, 03-30-2007 18:08:32
seems easier to drill out the hole to a certain size and HAVE a bronze bushing made to match it and the clutch pin.
Frank, Tx
03-30-2007 18:22:46
Don't know, but since you are going to need a new bushing, go ahead and buy it and measure the O.D. of the new bushing. Frank, Tx
