Clydes flywheel installation problem solved
clydeNS
03-30-2007 15:28:10
Thanks to the help from the great people using this forum!A few weeks ago I wrote about not being able to get the mag drive slot to be horizontal when the flywheel was on the timing mark.The problem was the cam was one tooth out of time with the crank. The previous owner said he could never get it to idle very good,now i know why.
P Browning
03-31-2007 02:16:13
 Re: Clydes flywheel installation problem solved in reply to clydeNS, 03-30-2007 15:28:10
Clyde -- what a beautiful find! The seldom-used timing test to check valve timing is one many of us need to be mindful of these days because there are so many EXPERIMENTERS out there as some of the commentary on this forum will reveal!
And yes, failure of the magneto flange to be parallel with the crankcase cover surface is the tip-off that the cam-to-crank timing may be off.
I wanted also to commend you for coming back and telling of the end result. More often than not, such a comment has tremendous impact -- good impact! (PatB)
