861 ford steering box
Richard Willard
03-30-2007 06:18:58
Hello tractor experts.
This is the man with an elderly friend with a John Deere tractor, with bacteria clogging the filter in the lift..also answer this if you hace more info..
I have another friend with a problem. The 861 gas ford tractor steering box allowes the steering wheel to rise up instead of turning the wheels. Is there a pin or nut that holds the steering wheel in place? What parts are available? Thanks
Richard [email protected]
Bob
03-30-2007 06:40:50
 Re: 861 ford steering box in reply to Richard Willard, 03-30-2007 06:18:58
The upper steering gear bearing has failed. The steering gear will have to be rebuilt. The bearings; seals and gaskets SHOULD still be available from CNH.
You can look up the parts on their site.
