2555 Hydro filter
cattlefarmer3020
03-30-2007 06:15:42
Hi,
I was changing the hydraulic filter on my 2555 last night, and was having trouble getting the metal return line loose from the filter cover. Until the line comes loose I cant get the filter changed. Something that should take five minutes took an hour and a half and still dont have the line loose. Is there a trick to this or could the fitting just be frozen up tighter than it should be? Any tips will be very appreciated
Glen in TX
03-30-2007 11:40:08
 Re: 2555 Hydro filter in reply to cattlefarmer3020, 03-30-2007 06:15:42
Heat the line nut some with a torch and it will come loose. Just be sure to have tractor and area clean of grease, spilled oil and stay away from batteries and wires. Don't cut it just heat it to expand it and will come right loose and won't hurt if you don't melt it.
