JD 1020 Diesel
Capt Dick
03-30-2007 05:36:40
I fired it up last night without the manifold front and back cylinder 1&3 ran clesr after start up, No. 2 smoked and appeared to be exhausting some unburt fuel. Suggestion?
jdemaris
03-30-2007 06:22:04
 Re: JD 1020 Diesel in reply to Capt Dick, 03-30-2007 05:36:40
That's not uncommon - and several things can cause it. Number one problem on the 152 c.i. diesel is that #2 piston broke the top piston ring. The top rings on that engine break pretty easy - especially is ether has been used for starting - or the ring grooves are worn. With no top ring at all, once the engine gets good and hot the cylinder will start to fire. There can be other things as well. If you ascertain there is fuel going to that cylinder, and the injector is not plugged, then it's time to pull the head off. Takes less than one hour - and you will see right away if a broken ring is the problem.
Capt Dick
03-30-2007 10:21:06
 Re: JD 1020 Diesel in reply to jdemaris, 03-30-2007 06:22:04
Thanks,
I'll give it a try over the weekend. Yesterday was the first time I've had it running for any time and then just for a minute since I didn't have the new manifold yet. After removing and checking all my fuel lines for blockage I pull the NAPA 3166 filter that I just replaced and found it had no hole except the center on either end. The new JD Filter in it fired right up. Just like a boat when you fix one thing you find another I found a crack in the top of the tranmission housing when I removed the seat. Does it need to be brassed or will marinetex hole it?
