1946 B Oil Fill Location
JD Gimpl
03-29-2007 17:27:59
OK I did a real stupid thing. I drained the oil and changed the filter. NOW I can't find where to fill the dang thing back up. I have called 2 dealers and both tell me a little cap held by 2 clips by my right foot but it is not there. Would anyone have a copy of the parts or service page showing me where to find this. I ordered a book today but won"t have it for about 10 days.
Also could you tell me how much oil to put in, thay might be helpful...
Thanks Gimpl.
JD Gimpl
03-30-2007 07:57:47
 Re: 1946 B Oil Fill Location in reply to JD Gimpl, 03-29-2007 17:27:59
Thanks Everyone... I will have her running in 30 minutes.
Gimpl
johns48jdb
03-30-2007 04:30:42
be sure you choose the right screw to unloosen. the screw to set the oil pressure is right there too. seems like on my 48b that that there is 4 hex headed screws right there close together and the oil check plug is the one cloeset to the rear end of the tractor. better look at more answers first. i'll check on mine between now and lunch and check back in with you.
Mike M
03-30-2007 04:54:24
 Re: 1946 B Oil Fill Location in reply to johns48jdb, 03-30-2007 04:30:42
On a 46B the oil pressure adjustment is inside of the crankcase on top of the oil filter head casting if I'm remembering correctly ? Only the later ones from #201,000 and up had it external.
Ken Thies
03-29-2007 18:22:39
The breather pipe in the middle of the cover in front of the steering wheel screws off.
1 1/2 to two gal. open the oil level check cock on the right side under the clutch pulley and keep an eye on it. When it begins to drip quit.
Ken
Mike M
03-29-2007 18:20:36
A hand start ? has a breather just ahead of the steering post unscrew the top with the stack on it from the crankcase cover casting,remove breather filter then dump in engine oil until it runs out the oil level test cock. Not sure if the test cock is on the RH or LH side I think RH on that model anyhow it takes a 3/4" wrench to loosen. Also the body of it has the same size hex and is alot longer than a reg. nut.
Electric start models you should have a breather or a large screw on cap on the RH side next to the rear of the hood add oil here.
