B Transmission
Tom R Ne
03-29-2007 14:03:16
I once owned a 1941 B, which I sold about 45 years ago, I was trying to remember the gear configuration on the B's.
If I remember correctly they had a 4 speed transmission until about 1941 when they went to a 6 Speed with two sticks, a 3 speed plus a high/low shifter. If memory serves me correctly the one I had would move the Hi/Lo shifter to low when you put it in reverse.
I seem to remember that in about 1950 or so they reconfigured the transmission to a single stick 6 speed; but I am wondering if I'm confusing that with a either a later model A or a 60 both of which I used back in the mid and late 50's.
Any clarification would be appreciated.
Thanks Tom.
machinery-man
03-30-2007 09:14:28
 Re: B Transmission in reply to Tom R Ne, 03-29-2007 14:03:16
that's a good one about removing a pin and having high speed reverse. I thought the fork carrier were hitting each other causing the unit to operate only in the Ist speed in reverse. It seems like it would push the underdriver lever out. But who on earth would want a faster reverse on those tractors. As I recall the tractor all had the underdriver shifter just not the external gears. My unstyled B had the underdrive shifter but no case external gears.
Ford 312
03-29-2007 14:18:18
I learned to drive a tractor on a 1941 B. Reverse was on the bottom left, with 1-3 on bottom right. Above 1-3 was 2-4 the to the top left was 5-6. When putting shift in reverse the hi-lo lever would go to lo. I have heard you could remove a pin in the transmission and use reverse in the high side. The six speed single shift lever came out in the 1948 late styled model B's. I believe the six speed single shift lever didn't come out until 1950 on the A's.
Tom R Ne
03-30-2007 01:45:19
 Re: B Transmission in reply to Ford 312, 03-29-2007 14:18:18
Thanks for the information. I just hate it when I have these "Senior moments", but after 45 or more years go by it is hard to remember the little details.
That B had a primitive old loader that had hydraulic cylinders that operated cables to lift the arms, and of course it had a trip bucket. The dang thing put most of the weight on the front tires and it sure was an aggravation to operate (that part I don't have any trouble remembering).
buckeye al
03-30-2007 15:13:53
 Re: B Transmission in reply to Tom R Ne, 03-30-2007 01:45:19
Had a loader like what you describe. Long ago it went to scrap but seems to me maybe it was a McGrath loader?
Twin cylinders on a crosswise bar under the tractor belly with a cable sheave on top of each. Cable was anchored to the frame & went up over the sheave then down the outside to the straight pipe arms which went from the rear axles to the bucket? Wouldn't raise real high 'cause the B wouldn't hold enough oil for those big rams?
Was a bear to run 'cause you had to clutch, raise (or lower), trip the bucket, re-trip it 'cause it had two latch holes one for digging a litle & one for digging a lot but it never seemed to stop in the one you wanted. Had to do all this at once and still steer. It was still easier and faster than forkin!
Had almost forgot about that old loader.
Later.
Tom R Ne
03-30-2007 15:49:13
 Re: B Transmission in reply to buckeye al, 03-30-2007 15:13:53
Yep Al: Your's sounds like the same loader, I don't remember the manufacture but it seems like it was made in Sioux City, Ia. Probably several different manufactures that use a similar design?
Several more hands would have came in handy to run that old rig, thats for sure.
You're right on the money about the bucket latch, getting the bucket latched in the hole you wanted could really be exasperating.
When it was the only loader I had I felt like you did, it beat a Scoop Shovel or Manure Fork all to pieces.
