730 Diesel voltage - 24-12 for the headlights?
Scott Dunn
03-29-2007 13:05:29
I'm asking this on behalf of my dad. He is restoring a 730 Diesel and he can not seem to get the voltage to reduce from 24 to 12 for the headlights. He has put a new Voltage regulator, generator, wiring harness and light switch, but none of that has worked. Any suggestions or ideas would be greatly appreciated.
Thanks!
Scott
machinery-man
03-30-2007 08:35:31
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to Scott Dunn, 03-29-2007 13:05:29
Have been helping an 80 year old friend with 730 diesel...did all the wiring, new regulator, new switch but the voltage is not right to the lights, one dim and then on other position the other dim. Spent a couple of phone calls to him yesterday telling him that the batteries are not grounded. He has 2 14 volts hooked in series to the starter, the other wires are correctly positioned but I see now that he does not have the grounding wires between the batteries. Is this the cause of the variation in voltage? Thanks Chuck
buickanddeere
03-30-2007 11:22:55
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to machinery-man, 03-30-2007 08:35:31
Correct. The center point between either both or both pais of batteries must have a reference to chassis. This reference point maintains the 13.8V on both 12V systems as the loads are rarely perfectly balanced. This reference tie to chassis should be fused at 15amp. It can't hurt to put an isolation switch in that circuit too. Should the starter get sooted up, one battery won't be drained.
Gerald J.
03-30-2007 09:03:23
The ground wire missing (or sometimes it had a fuse and that fuse could blow from an accidental ground on either 12 volt system) would be the major cause of voltage unbalance. Unbalanced loads so one battery was charged better than the other leads to smaller voltage unbalance, and unbalanced battery life.
Gerald J.
mjbrown
03-30-2007 05:56:47
These guys know their 12-24V systems. I have a 730D and I'm thinking 24V alternator and lights and the heck with the split load mish-mash. I know it's not ORIGINAL but originality only floats my boat till it gives me a headache then simplicity becomes my mistress. I'm still in the thinkin' about it stage so if someone has tried it and found a reason why it won't work please share.
buickanddeere
03-30-2007 07:05:11
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to mjbrown, 03-30-2007 05:56:47
It would work if a solid state voltage regulator was used to supply 12V to the fuel tank sender.
mjbrown
03-30-2007 16:11:40
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to buickanddeere, 03-30-2007 07:05:11
Ah yes the fuel sender. Forgot about that little rascal. Thanks.
John T
03-29-2007 13:41:31
Scott, Mines pretty well the same answer as Bobs, just a different spin. All the mess n gazillion wires is the reason Ive refused to try n offer this dern system at any seminars, looks like Tom is gonna tackle it.
Like Bob noted the two 12 volt batterys, where they are tied in the center series connection, happens to be bonded to the frame. Therefore its 12 volts from either outermost untied battery post to frame ground, just that ones Pos n the other Neg ground (lights dont care) Nowwwww those hot Pos and Neg circuits are both fed up to the light switch n called the A and B input circuit feeds. The switch serves some lights off A and the other B and its those hot A and B feeds up on the light switch where the 12 volts with respect to frame ground is located.
Buttttt ttttt ttttt tt if where the 2 batterys are tied in the center isnt bonded to frame ground, there wont be 12 volts with respect to frame ground to make the lights work !!!
Insure that where the 2 batterys are joined in the center theres a wire to frame ground. The center is the + of one battery and - of the other that DO NOT GO TO THE STARTER SOLENOID. The outermost untied battery terminals (that lead to starter) are 24 volts across cuz thats the two 12 volt batterys in series.
Clear as Mud Im sure lol
Insure the center is tied to frame and then put a voltmeter up on the light swich and where two bigger BAT input wires connect to the switch there ought to be 12 volts from either to frame ground.
John T
HTR
03-29-2007 17:28:16
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to John T, 03-29-2007 13:41:31
John, I have never seen the part the path of least resistance plays discussed, in the twenty four volt split load systems. With part of the lights on the A circuit, and parts of the lights on the B circuit, also the fuel gage and oil pressure light on one of the circuits, the path of the least resistance, is through the common ground wire for the twelve volt circuits. Now if the common ground is not present, and you turn the lights on, The path of least resistance is through the filaments of the lights on one circuit, through the frame of the tractor, and through the filaments of the lights, on the other circuit. This puts the lights in series with the twenty four volts, less the resistance of the filaments. So he may have more than twelve volts, in the light circuit, with just the common ground missing, but not to frame ground.
You can't achieve a balanced series circuit because of the single rear light, oil light and fuel gage, in one of the circuits. I may have some new generation mixed in, I don't remember if the 730 electric start has an oil light. Ever notice when the oil light and fuel are not working, turning the lights make them work. Then you know the common ground wire is bad. Their circuit is completed through the lights, but because of the unbalanced load, you are going to blow the lights on one of the circuits, and usually melt the lens on the oil light.
John T
03-30-2007 06:08:21
 Re: 730 Diesel voltage - 24-12 for the headlights? in reply to HTR, 03-29-2007 17:28:16
Wow, GREAT discussion n good info. Now ya see why I never wanted to really learn the system in depth enough to try n teach it to others lol.
I understand n agree about the light circuits being in series across 24 volts n bonded at their frame ground points and if their filament resistances were the same they would each drop 12 volts. I reckon in that case the lights could still work EVEN IF THE BATTERY GROND WASNT THERE !!!! And similarly, if the loads werent exactly balanced (likely the case) one would be higher n the other lower then 12 volts as you pointed out..... .
I never tried to look in any detail of the load balances on the 2 batterys but always wondered how with back lights and indicator lamps n gauges etc how there could ever be ANY EXACT EQUAL balance. I always just figured Mother Deere designed it the best possible so the loads would only be APPROXIMATELY BALANCED. A gauge here, an indicator or rear lamp there etc so the loads are approximately balanced,
I hope Tom explains all this in the 2008 GOG Seminar on 24 volts, based on one he gave in the past Im sure he will do a good job and me in teh front row taking it all in.
Fun discussion, yall take care. I try to not get in the 24 volt stuff too much, let Gerald J n Buickndeere n ET n you n others tackle it lol but thought I could provide some help to the posters original question here
John T
Scott Dunn
03-29-2007 15:08:41
Excellent info. I will pass this along to my dad today and will keep you posted on the outcome.
Thanks again to all!
Scott
55 50
03-29-2007 13:34:51
The most logical thing to check is to make sure the "center point" is tied to tractor chassis as Bob mentioned. Ron (retired electrical engineer) On tractors I've seen, that centerpoint is usually a wire inside the battery compartment. It's not a really heavy wire (#12 or #14 is plenty heavy for this) since it carries only lighting current, not starter current.
Bob
03-29-2007 13:20:23
Here's the quick; simplified version:
The 24-Volt battery system has it's centerpoint grounded to the tractor's frame (chassis).
1/2 of the lights operate on (plus) 12-Volts and 1/2 of the lights operate on (minus 12-Volts. (In relation to "ground" (the chassis)).
The generator charges the batteries at 24-Volts and the starter operates at 24-Volts. (Nominal)
Mike M
03-29-2007 13:10:44
Alot of new parts ,but all it takes is one wire to be stuck onto the wrong place to really goof you up. On mine I stared at the wiring diagrahm for days and still messed up and hooked up one wire the wrong place. I'd say if you don't have a wiring diagrahm get one and if you have one double and triple check it.
