48-A Drive Wheel not flush with end of Crankshaft?
Sam in MN.
03-29-2007 12:25:40
48-A
The new aftermarket Clutch Drive Wheel is not flush with the end of the crankshaft. I drove it on hard and it is tighter than all get out. I locked the flywheel from turning, so I know I have full 150 lbs. torque on the end bolt.
Right now it is about 0.20" from being flush. Is this going to be an issue or do I need to pull the stupid thing off again?
Sam
NortexJD
03-29-2007 16:18:12
 Re: 48-A Drive Wheel not flush with end of Cranksh in reply to Sam in MN., 03-29-2007 12:25:40
I'm with JohnT, check the ignition switch. Had a similar problem with my 47A.
Mike M
03-29-2007 13:06:08
You say 0.20" that's about 1/4" 0.250" THE GOOD NEWS IS THAT'S PERFECT !!!! CONGRADULATIONS you must have one of the very few A's left that the driver doesn't go on that crank too far. I can't tell you how many I've had to patch up to get that driver out so the clutch will work right.
ram ranch
03-29-2007 12:51:36
STOP while your ahead! listen to what F-I-T said!
MikeinKy
03-29-2007 12:42:30
I think as long as it doesn"t go in past the end of the crankshaft it is all right. Being out .020 shouldn"t hurt. I haven"t looked at my book lately. You should be OK.
F-I-T
03-29-2007 12:40:53
Sam:
STOP BANGING ON IT RIGHT NOW !!!!!
You have two "tapered", splined surfaces. The driver should always sit "proud" of the crankshaft end if both surfaces are in spec. The real problems come when it does slide on too far, and then you have a real deal trying to keep it tight.
You probably worked real hard to get it where it is. I hope you don't have to remove it for a while! It is probably really swedged on there.
Frank
Sam in MN.
03-29-2007 15:01:45
 Re: 48-A Drive Wheel not flush with end of Cranksh in reply to F-I-T, 03-29-2007 12:40:53
Well you guys just made my day!!! I did use a small hammer (Not a maul.), with a piece of soft 2 x 4 pine, so she is snug but I think it would come off with a puller and a little heat. I would rather struggle to get the driver off, than tear up the splines on my shaft.
Yes the clutch works really nice with plenty of adjustment left.
Thanks for all your quick responses.
Sam
zwr
03-29-2007 16:11:49
 Re: 48-A Drive Wheel not flush with end of Cranksh in reply to Sam in MN., 03-29-2007 15:01:45
Be thankful for that open hole and good threads in the end of your crankshaft! I never had the guts to bring my driver bolt up to full torque, but I would check it often to make sure it's all still snug.
