LUC oil pump
BMA70
03-29-2007 11:50:08
Hi
I've just been looking over the oil pump and found a small hole maybe 1/16 drilled though the pump body into the oil gallery on the pressure side of the gears, so that when the pump is run a jet of oil comes out of this hole as well as the main outlet. my question is this hole supposed to be there? and whats it for?
thanks in advance Barry
bma70
03-31-2007 13:00:31
 Re: LUC oil pump in reply to BMA70, 03-29-2007 11:50:08
thats my thoughts too braze it up the relief valve seems plenty big enough to deal with anything that little pump can produce.
norv
03-29-2007 18:34:20
Your story brings back memories of the luc that my dad had on a jd 12A combine. It always had poor oil pressure until my uncle tore it down to overhaul and found a hole in the oil pump body just like you describe. he thought it was a sand hole that happened during casting. anyway, he brazed the hole shut and it had great oil pressure after that.This happened many years ago when i was still living at home.
