2240 Transmission
Pete/ME
03-29-2007 02:52:56
How can I tell if my 2240 Ser.#183999L has a "Collar Shift" or "Syncro" transmission. It came up when I checked capacities at the dealer for refilling the trans. oil and coolant. My S.M. just gives one quan. with no mention of either trans.
dds-inc
03-29-2007 08:47:10
 Re: 2240 Transmission in reply to Pete/ME, 03-29-2007 02:52:56
collar is the shifter on or near the dash. Synchro is the two sticks on top of the transmission in between your legs as you sit. (no pun intended there...lol)
Tx Jim
03-29-2007 10:49:04
 Re: 2240 Transmission in reply to dds-inc, 03-29-2007 08:47:10
duds-inc,Do you mind clarifing your post about collars and syncro's !!!!! !! What 1st grade reader did you get the info from? (no pun intended) Tx Jim
Tx Jim
03-29-2007 03:34:36
Pete,I don't rememeber 2240's having a sycro-shift transmission when I sold them new,collar- shift is all I remember. They did have hyd hi-lo or reverser as an option. Tx Jim
Pete/ME
03-31-2007 02:22:00
 Re: 2240 Transmission in reply to Tx Jim, 03-29-2007 03:34:36
Mine has the two sticks on the trans. cover. The left one is I,II,P(ark)&R(everse), the right one is 1/5,2/6,3/7 and 4/8. I've never seen one with the shifters anywhere else. (Except my 4020 P.S.) Maybe a regional thing?
Tx Jim
03-31-2007 04:05:25
 Re: 2240 Transmission in reply to Pete/ME, 03-31-2007 02:22:00
Pete,if your tractor doesn't have a lever on LH side of dash resembling the throttle on RH side it is a collar shift. The lever on LH side is for hyd hi-lo or hyd reverser. I never saw or sold a syncro shift 2240. What manual or book are you refering to? Tx Jim
