D's fenders are trouble
Farmboy169
03-28-2007 20:04:48
Let me start off by saying that I'm not the best welder, but I get the job done. I have been trying to patch a few rust holes on the fenders of my D (mostly the inside part of the fender). The metal is so thin that it burns thru right away. I have the welder as low as it will go and it still does it. Is there a better way to weld these or maybe an alternative to welding?
Glen in TX
03-29-2007 09:33:31
 Re: D's fenders are trouble in reply to Farmboy169, 03-28-2007 20:04:48
There are new fenders out there but they stick out a mile away as not being original with the beading and edge not right on any of them I've seen yet. You have to save all the old irons and rivet them on the new ones too.
Mike M
03-29-2007 08:11:30
A couple of alternatives could be some types of body filler or fiberglass mesh and rosin ?
Also many sources of brand new fenders out there too.
Are you using a mig welder ? It should work with the copper underneath trick as mentioned below.
Shawn
03-28-2007 20:31:16
Try clamping a flat piece of copper on the other side (I use copper pipe flattened in the vice).Weld won"t stick to it and the copper will hold the molten metal in place until it cools.Pry off the copper and grind down the weld on both sides. Works very well for me..Copper can be bent to fit in corners and curves.
