2010 JD Engine Parts
hbarnhardt
03-28-2007 17:49:51
I'm having a difficult time locating engine parts for a 2010 Diesel JD. I would appreciate your assistance in locaating these parts. Main Bearings, Con rod bearings, Head gasget, and gasget for cylinders, Rings, oil pan gasget. I think really I need a com;lete overhaul kit. Thank you very much for your assistance. I have checked first with these people and they do not have the parts I need. THANKS
joe stewart
03-29-2007 10:39:22
 Re: 2010 JD Engine Parts in reply to hbarnhardt, 03-28-2007 17:49:51
I bought rings and bearings for my 2010 diesel at Engine Parts Warehouse in Baton Rouge, but that was about 6-7 years ago. Not sure if they still have them. Bought all the gaskets you mentioned from Deere. Good Luck
jdemaris
03-29-2007 05:54:33
To my knowledge, nobody has ever sold engine-kits for the 1010/2010 series, not even Deere. But, Deere has all the major engine parts still available. There's a company in China that's making a few parts, e.g. pistons and sleeve-decks for the 1010 diesel or 2010 gas (sleeve-deck is the same for either).
Glen in TX
03-28-2007 20:59:36
Aftermarket has kits for 145 gas but don't know of any for that 165 diesel except from JD. http://jdparts.deere.com
hbarnhardt
03-29-2007 16:47:20
 Re: 2010 JD Engine Parts in reply to Glen in TX, 03-28-2007 20:59:36
Thanks for all the replys. I shall follow up with your suggestions. The motor ran good about 18 months ago, then I go out to start, place a new battery, and just a click. Thought it was the starter, but was not. Tried everything to break it loose, flywheel prying, pulling and pushing with bobcat in gear---nothing. So I pulled it down, pulled the head and wow, never seen so much rust. It appears water must have entered somehow. Anyhow got the pistons to move but--and I didn't knkow this--all the jugs came up and broke the gasgets. Had never seen four jugs on one (welded I guess) plate of steel.
Now my goal is to get it back together with the proper gasgets, along with any new parts that I can locate. Thanks to all.
