oil seals
Ben Lanpi
03-28-2007 17:25:39
ok, I got the wrench needed to remove the flywheel on my 44 B took the bearing cover off then the flywheel spacer. My IT manual say a cork seal is between the flywheel spacer and the bearing housing. Is this correct? Ididn't see one when I looked on mine.
Anyone living in Michigan know where to buy John Deere parts? I've beed to D&G but I think thier pricey $37.50 per petcock is that high or about right. Thanks for any input. Ben L.
teddy52food
03-29-2007 18:40:09
 Re: oil seals in reply to Ben Lanpi, 03-28-2007 17:25:39
I just redid my 44 B. I found that 3 square cut seals from a C 4 Ford automatic transmission will fit real good & are not so easy to damage when I put it back on.
Sam in MN.
03-28-2007 17:47:18
Ben,
Just rebuilt a 48-A and all those special seals like the cork one is available at your local JD Dealer. Yes they in general they are a little more, but for gaskets & Seals it really is not that much. JD still sells about anything that wears on the old 2-cylinders.
Oops, there is an exception! They no longer sell the gasket for the crankcase cover for an "A".
Check inside the flywheel spacer for the old seal. It is most likely stuck in there. Be careful putting the new on the shaft, as it can chip or break real easy. A little oil will help.
Sam
Ben Lanpi
03-29-2007 13:28:57
 Re: oil seals in reply to Sam in MN., 03-28-2007 17:47:18
Thanks for the input. I was afaid the JD dealership was the put to give my money too so be it. Thanks again Ben L.
