520 Throttle Rod
RichieWis
03-28-2007 14:24:16
Brother-in-law just picked up a 520 and the throttle rod is bent.Wondering if maybe it should be and if not where would be a good source for replacement ? Thnks in advance
ihfan
03-28-2007 18:55:08
 Re: 520 Throttle Rod in reply to RichieWis, 03-28-2007 14:24:16
I used to bend those rods to get more speed always bent them back after the boss cought me.
RichieWis
03-28-2007 16:32:10
Thnks guys for the quick responses.Much appreciated
Glen in TX
03-28-2007 16:03:37
Parts book shows the rod that goes from governor arm to carb has slight bend in it almost in middle or 2/3 way back. I looked on a 520 LP outside the and the bend is actually down and farther back a few inches from threaded end. Parts book shows same rod for gas or LP, B3644R throttle rod. The other rod B3984R (sub. B3461R) from spring back to lever is straight except for the bent end that goes in spring.
machinery-man
03-28-2007 15:45:58
You can easily straighten or use round stock and thread it...
uoflncolts
03-28-2007 14:33:52
Are you talking about the rod you physically move or some leakage rods? If it is just the casting piece that you place your hand on, you should be able to heat it and bend it back. However, since it is cast, you take a chance of breaking it. Being a 520, if it breaks you should not have to look hard for a good used one, place an ad on the classifieds on the left. When we straighten more expensive throttle rods like the 80-830, we take them off heat and straighten them and then place it in sand or lime to allow them to cool more slowly. Good luck, if you cant straighten it or find one, I think we have a good one on a parts tractor, email me for details.
