G Magneto
Weldin Man
03-28-2007 14:02:58
Can anyone tell me the proper procedure for timing the magneto on a John Deere G ? I don't have a service manual on these old boys. Thanks in advance.
Glen in TX
03-28-2007 15:49:04
 Flange Mount Mag Timing in reply to Weldin Man, 03-28-2007 14:02:58
If these generic instructions don't catch it tell us which mag.
Magneto Timing for JD D and other Waterloo JD tractors with flange mount magneto :
1. Remove spark plugs from the engine and turn flywheel forward in direction it runs until you feel some pressure of air coming out the LH # 1 cylinder (flywheel side) spark plug hole as it is coming up on compression stroke. (If you don�t feel or hear air coming out it is on exhaust stroke and keep rotating till it comes up on compression stroke.)
2. Turn slowly as it comes up on TDC (top dead center) of compression stroke and watch as the mark on flywheel �L.H. Impulse� comes up in line exactly at the 3 o�clock position with the mark on transmission cover or housing. Stop when marks are in line with each other. (Note): The later model A,B,AR, & 50 tractors with flywheel cover will have a mark or notch on lower end of cover hole to align with flywheel punch mark instead of marks mentioned above.
3. In this position the slot in coupling on governor shaft should be horizontal. If it is not horizontal when LH cylinder is at TDC and governor had been removed previously this will have to be aligned and corrected first.
4. If slot is now in horizontal position you are ready to install the magneto.
5. Make sure points are set at .015� for Edison Splitdorf and Wico magnetos.
6. Edison Splitdorf magnetos when mounted use the forward terminal on distributor cap for # 1 LH cylinder. Can mark with chalk if necessary. 7. Wico magnetos will use the top terminal in distributor cap for #1 LH cylinder. Can mark with chalk if necessary.
8. Connect wires and spark plugs in distributor holes of magneto and have the magneto frame and plugs grounded with plugs out of engine.
9. While turning the magneto slowly in a left hand direction (CCW) facing the drive end watch for a spark from the #1 LH cylinder plug that would be connected to forward terminal on Edison magneto or top terminal on Wico magneto.
10. When you get a spark on the LH terminal stop and the drive lugs of magneto should be in a horizontal position. 11. Being careful to not disturb that position install the magneto on tractor using one or more flange gaskets and install bolts only finger tight.
12. If you notice a binding and magneto flange does not pull up tight to flange when tightening bolts finger tight you may need to shim out with more gaskets being careful drive lugs align in slots also.
13. Then rotate the top of magneto toward the front of tractor as far as possible.
14. Then slowly rotate the flywheel forward one complete turn slowly coming up on the �LH Impulse� mark on flywheel to align exactly again with cover mark at 3 o�clock position. Then stop in this position. 15. If you went past the mark you can rotate the flywheel back and come up on mark again but if you rotated too far forward and tripped the impulse in magneto you will have to remove magneto and start over. 16. Now carefully and lightly tap the top of magneto slowly toward the rear of tractor a little at a time until you hear the impulse trip. Stop.
17. Tighten the bolts holding magneto to governor case taking care to not over tighten. If flange does not pull up flush do NOT over tighten to pull it up more.
18. Use another gasket to shim magneto farther out instead. Failure to heed this advice shimming the magneto properly with gaskets can result in breaking the magneto housing. 19. Problems getting magneto to align by having to use several gaskets may also indicate previous improper assembly of governor or worn governor parts.
20. Gap spark plugs at .030� before installing in cylinders. 21. Install spark plug wires so wire in upper terminal of Wico magnetos or forward terminal of Edison Splitdorf magnetos is connected to the LH cylinder spark plug. Lower or rear wire connects to RH cylinder.
22. If magneto is equipped with a threaded stop terminal you may add a shut off grounding switch to this terminal.
23. NEVER connect battery voltage to a magneto or to stop terminal !
24. A magneto produces it�s own power and does not need power from a battery.
Weldin Man
03-28-2007 17:54:11
 Re: Flange Mount Mag Timing in reply to Glen in TX, 03-28-2007 15:49:04
Thank you very much for the directions. This G has a Wyco mag . We installed new points, condenser cap and rotor, plugs and wires but it still fluttered at 3/4 to full throttle. I advanced the timing a little and it seemed to help, but I wasn't sure how to check the timing after getting it up on impulse. I will check it again tomarrow if possible. Thanks Again
Glen in TX
03-28-2007 20:51:56
 Re: Flange Mount Mag Timing in reply to Weldin Man, 03-28-2007 17:54:11
If that doesn't work post back and we'll figure out if your impulse is set on that Wico. Mag impulse parts or bushings or bearings can get worn causing some fluttering too.
John T
03-28-2007 15:08:28
 Re: G Magneto in reply to Weldin Man, 03-28-2007 14:02:58
It will save us both time if we know the make n model. If its like a Wico C or X (direct drive non reduction) I can tell ya how I do it but if its one of those FM"s or Wico AP"S Im OUT TO LUNCH n Duane or Glen or others will have to help ya. Theres the initial static "impulse" start timing and the advance run timing you gotta be concerned with and lag angles n that other stufffff ffff.
John T
John T
