Changing 4010 to 12 volt
Jeff McBride
03-27-2007 22:34:06
Do you have much trouble starting a 24 volt tractor that has been converted to 12 volt in the winter. Someone told me several years ago to leave it 24 volt because they start a lot better in the winter but it goes thru a set of batteries about every two or three years and even with a new set sometimes I have to charge them with a charger to get it to start. The generator either charges them to much or does not charge them at all. I put new voltage regulator on, rebuilt the starter and generator and it still does the same. I have been thinking about changeing to 12 volt but the batteries are cheaper than a new starter. Any thoughts on the pro's and con's?
Thanks Jeff
Tim in Western PA
03-29-2007 18:55:00
 Re: Changing 4010 to 12 volt in reply to Jeff McBride, 03-27-2007 22:34:06
Kit was one part number from deere. It included the alternator, starter, starter relay, new negative cables, bolts, solineod, pretty complete. I had to buy a new fan belt. My old one was too short.
Bob
03-28-2007 14:26:04
Just a THOUGHT...
Save the 24-Volt parts in a clean; dry place for the next guy who wants to restore the tractor!!!!
As collectible as these tractors are becoming; I'd think TWICE before "farmerizing" mine!
(Do you suppose the guys of 40 or 50 years ago gave collectors a thought when they threw away the 2-cylnders' special hood bolts and extra-wide implement attaching bolts and "cut" the hoods?)
Bob
03-28-2007 14:30:37
 Re: Changing 4010 to 12 volt in reply to Bob, 03-28-2007 14:26:04
Scratch "bolts" and substitute "nuts".
Gary in TX
03-28-2007 11:13:37
I converted my 3020 by doing nothing more than putting a 12 volt starter on it, adding a one wire alternator and connecting together the I believe it was the blue and brown wires off of the volt regulator. Same at the starter on the blue and brown wire. No kit involved. Works fine.
JD40203020
03-28-2007 07:20:35
I have a 3020 and a 4020 that are btoh 12 volt, and live in northern NY... Long story short I have no problems with winter starting. Only advise it on which starter you use. Ona 3020 that cranks easier that the 6 cylinder it doesn't mater if you use the Delco or Denso starter. But on the 4010, 4020 you will want the more expensive Denso starter. It will spin a lot faster than the Delco and thus will start that 6 cylinder a lot easier than a Delco will. I say go for it....
Ralph Wilks
03-28-2007 07:55:56
 Re: Changing 4010 to 12 volt in reply to JD40203020, 03-28-2007 07:20:35
Are the tractors diesel or gas? I just bought a 4020 diesel and it doesn't want to start unless I plug in the engine heater for an hour or two, depending on the temp.
How much was the conversion kit to convert from 24 to 12?
Jd 4020 3020
03-28-2007 09:03:40
 Re: Changing 4010 to 12 volt in reply to Ralph Wilks, 03-28-2007 07:55:56
Both Diesel. Both get plugged in. Its the nature of those engines to not start well in the cold without being plugged in. Some do start better than others. depends on engine wear, injection settings.... My 3020 will start at 0 without being plugged in, but it starts easier when it is plugged in. My 4020 will not start below 30 without being plugged in. The kit cost? don't know... Starter $$300- 400 I think depends on what you buy and if you can get a core refund for the old one. Delco alternator can be had for about $40. Battery cables? And a few other minor wiring changes shouldn't be too bad.
Gerald J.
03-28-2007 09:01:28
Only the diesel tractors were ever made 24 volts. Gas and LP were always 12 volts.
Gerald J.
tim in western PA
03-28-2007 05:41:10
I recently posted the same question. If you search, you find that most felt it was better. I finished the swap last weekend. I bought the JD kit from my local dealer. It's fairly complete. easy to install. The wiring instructions were pretty good. I missed one hot wire during my initial installation and only had half of my lights. (easy fix) I had to purchase a new fan belt(old one was too short) and need to get a new positive cable. Time will tell, if it was the right thing to do.
Jim Presley
03-28-2007 10:23:36
 Re: Changing 4010 to 12 volt in reply to tim in western PA, 03-28-2007 05:41:10
Tim, was there a single part number from Deere for the kit you bought? Was it everything you needed?
Thanks,
Jim P
