620 JD....Power Steering pump seal ????
Rich-WI
03-27-2007 16:38:36
I need to put a seal in the power steering pump on my JD 620 and do some other power steering adjustments. What manual do I need to order that is best suited for what I need to do ?
Thanks, Rich
Rich-WI
03-28-2007 06:37:52
 Re: 620 JD....Power Steering.... THANK YOU in reply to Rich-WI, 03-27-2007 16:38:36
G/MAN and Dan.....thank you, I just ordered SM2050 in the CD-Rom version from JD Service Publications. Should be here in a few days.
Thanks again, Rich
Dan in Ohio
03-27-2007 19:03:49
 Re: 620 JD....Power Steering pump seal ???? in reply to Rich-WI, 03-27-2007 16:38:36
Rich, The service manual SM2050 titled Power Steering for 2-cylinder tractor is what you want. It is not specific for just your 620 but covers the Waterloo built 2-cylinders well. I just bought it and would recommend the CD version as it is cheaper.
G/MAN
03-27-2007 16:49:09
You probably won't find anything pertaining to the power-steering system in the regular 620/630 tractor repair manual, but maybe you've already discovered that. Deere published a specific manual for the Waterloo two-cylinder power-steering systems. The number is SM-2016 from June of '57, and it should be available from JD Service Publications, or you might be able to beg, borrow or rent the manual or copy pages if your local Deere dealer still has it on the shelf and not packed away somewhere.
