720 G TRANSMISSON PROBLEM
HANK
03-27-2007 13:48:23
I HAVE A 720 THAT JUST QUITS MOVING IN 2ND AND 4TH GEAR WHEN PULLING HARD. IT DOES NOT JUMP OUT OF GEAR IT JUST QUITS MOVING. NO STRANGE NOISE. PULL THE CLUTCH LEVER BACK THEN ENGAGE IT AND IT TAKES OFF. BUT YOU NEVER KNOW WHEN IT IS GOING TO STOP AGAIN. ANY IDEAS?????
430WLPG
03-27-2007 18:30:04
 Re: 720 G TRANSMISSON PROBLEM in reply to HANK, 03-27-2007 13:48:23
My 730 does something similar to that, sometimes you have to shift from one side to the other and back and then go back where you were. Usually does it when you go from hi side to low side. And what mine is doing is that there is a internal shifter that is only used when crossing from hi to lo and the stick never moves out of the slot, so that means shifter latch that locks it in gear does not always catch
Glen in TX
03-27-2007 15:04:09
Does the clutch snap in and out taking some pressure to make it do that? Clutch needs adjusted or probably is just worn out.
Kent Petersen
03-27-2007 14:46:30
your lower shaft brgs are worn and loose auj or replace as needed you may haft to replace thoses to gears also
