720 tires
pjcarlson
03-27-2007 11:44:25
Hello,
I need to replace the rear tires on my 720. It has Firestone field and road 15.5-38 on it now. The tractor sits a little low in the back, a situation I want to correct. I realize the 15.5s are a low profile tire. I want to get a tire that �looks� better over all on the tractor. It has a wide front with 6.5-16 on the front. Firestone has a couple of options 14.9 diameter 64� or 16.9 diameter 66.3� the 15.5s diameter is 61.6� all according to Firestones specs.
Would either of these replacements look odd on this tractor? Are there better options?
Thanks
Peter
almrm
03-28-2007 09:22:57
 Re: 720 tires in reply to pjcarlson, 03-27-2007 11:44:25
third party image
Peter,
My 2 cents: I am not a member of the correct police and my tires are not the correct size, but they are the correct height. This provides the gear speeds that match the owners manual. I think the 15.5 tire looks very nice on 620/30 and 720/30 tractors. Case in point, the original 620 on the cover of this months green magizine. Maybe another style or brand would look better to you. Attached is a photo of my 48 A with BF Goodrich 15.5s on 14 inch rims. I have sandy hilly ground and this tractor has had wider than stock rims all its life. I don't like wide tires on narrower rims. I like to keep all the tread flat on the ground. My BFG tires hang on good and look like the tire tread of the day. As stated earlier, its all about what you like.
Mark
Glen in TX
03-28-2007 08:02:28
Wouldn't use the 14.9 on a tractor that size unless you were still planning to run it for row crop cultivating as that narrower footprint size works well on smaller tractors for that like a 520 or 2510. Like others said check out some other tractors with 16.9 on them and see how they look to you.
DSK
03-27-2007 17:36:10
I know where you're coming from, I also think a tractor looks a little better when it stands level or has a slight forward rake. Switching to a 16.9 will only be a cosmetic improvement however, the 720 will not perform any better with the 16.9, in fact the same tractor with 15.5's would probably out pull it on a transfer sled. The 16.9's will cost quite a bit more than 15.5's also, they're really quite a bit more tire than a 15.5. Just some pros & cons on the subject.
pjcarlson
03-28-2007 08:46:13
 Re: 720 tires in reply to DSK, 03-27-2007 17:36:10
I am mainly after the proper look. This tractor will never see any real work. It has a loader that I use to clean out a horse barn, push some snow and move a little dirt to fill pot holes. I would guess it gets less then 200 hrs a year.
Merf
03-27-2007 16:13:30
I had a 720 with 16.9-38 tires. I did not like the looks of this tractor because of the BIG tires. I have five 720 and 730 tractors and all have 15.5-38 tires. These tractors have wide front, roll-o-matic or single front wheels assemblies. My choice is the 23 degree long/short bar Firestone 15.5-38. It is a little wider than my Good Year tires and seems to be a little taller. Each to his own on tires. I would suggest you look at other tires on tractors at shows/parades and go with what you like.
pjcarlson
03-28-2007 08:40:11
 Re: 720 tires in reply to Merf, 03-27-2007 16:13:30
I don"t want the tires to look over size or under size. Are the Firestones you use Field and Road or another style?
Mike M
03-27-2007 12:01:59
I doubt you would like the 14.9 so then you better go with the 16.9 these are tall. Just don't do like my 720 was a 15.5 on one side and a 16.9 on the other ! It was a little hard on the diff.
Ralph Wilks
03-27-2007 16:03:57
 Re: 720 tires in reply to Mike M, 03-27-2007 12:01:59
Yea but I bet it was great on side hills :-)
