3020 Brakes Resonating through ROPS
TomNTex
03-27-2007 09:50:59
I just recently installed a JD ROPS on my 3020. The rollover protection is added bonus but my main objective was a shade and to have some sort of removable protection that I could fasten to the uprights while running the shreader. Since I've had the tractor the brakes have always been pretty noisy. I've always used HyGuard and never found any trash or brake linings in the filters so i've been told this is sometimes the norm. However since installing the ROPS, the noise resonates through the hollow legs and really amplifies. Do you think I could put some rubber material between the leg base plates and axle to dampen the noise or would it still travel through the anchor bolts? My ears drums would appreciate any ideas or suggestions? Thanks
Tom
Resting Relic
03-29-2007 05:20:22
 Re: 3020 Brakes Resonating through ROPS in reply to TomNTex, 03-27-2007 09:50:59
When I worked for an International Harvester dealer in the early seventies,IH had a similiar problem with their Hydro tractors whining thru the ROPS. We used to fill the uprights with dig-able concrete. Basicly it was soupy mortor mix with a much less amount of cement. It worked really well.
TomNTex
03-28-2007 06:43:22
I never thought about filling the cavities with sand or foam. thanks for the ideas guys. This is why we come to this wonderful site. Thanks again for sharing your experiences and knowledge. Tom
low budget
03-27-2007 22:46:25
Deere used to fill them with sand.
RustyFarmall
03-27-2007 21:56:25
Drill a few small holes in the legs and inject them with "great stuff foam" or something similar.
G/MAN
03-27-2007 10:50:45
Yes, some Deere tractors with wet-disk brakes are more prone to chatter than others, regardless of oil used. It might be related to wear on the components, the surface finish of the brake disks or whatever, but it's usually hard to get away from. I suppose you'll just have to try some sort of insulation between the roll-gard bases and axle housing, but I wouldn't put much of anything in there besides maybe a thin strip of inner tube. Much material in there at all is going to be a point of flexing and may cause the roll-gard to come loose from the housings when you need it most, during a rollover.
