40T Differential Problem Update
Ned in TN
03-27-2007 09:11:31
Thanks to Henry M. and Jason Mills for the previous help.
Got the back of the tractor off and there are 10 little stripped out screws in the bottom of the case. The ring spins freely but both the ring and pinion seem okay from where I can see. I hope I can just back the screw pieces out and replace them. Not looking forward to removing both final drives.
The screws for the original differential from Deere are 50 cents a piece. The screws for the replacement differential are over $3 a piece and they are only one eighth inch longer.
How can I tell which differential I"ve got? The number on the ring gear doesn"t match to anything in the manual. Maybe it will be obvious once I get it out.
Thanks, Ned in TN
Jason Mills
03-28-2007 05:48:05
 Re: 40T Differential Problem Update in reply to Ned in TN, 03-27-2007 09:11:31
Ned, good luck getting all the pieces out of the ring gear. If you do, go to your local hardware store and get the correct length and thread grade 8 bolt. Pick up some brake clean and threadlocker while you are there. Use the brake clean to throughly clean holes that bolts go into. Then apply the threadlock on the bolts during reassembly. Maybe this will prevent a reoccurance of the problem you now have. Did some of them come out, then others sheared off? The final drives will have to come off for removal of differential. I would probably remove them to insure a good tightening and proper torque of the ring bolts. Would also be a good time to check bearings too. They are probably worn as well, check for metal pieces in them for sure. Good luck, Jason.
Ned in TN
03-28-2007 10:14:53
 Re: 40T Differential Problem Update in reply to Jason Mills, 03-28-2007 05:48:05
Jason
Thanks for the advice. Looks like all the bolts sheared off. I've probably been working this tractor too hard. I've plowed heavy clay and rock with a single bottom 18" turning plow and I've been pulling an 8' disc when the manual recommends a 6'. The disc came with the farm when we bought it. Guess I'll need to look for a used 6' disc.
Good idea on the brake clean and threadlock, and on checking the bearings, too.
Thanks, Ned in TN
Herny M
03-27-2007 17:24:04
Ned
I don't think you can get the diff out unless you pull both finals. I thought maybe you were thinking of just taking the rear cover off the trans and trying to work a repair by taking out the broken bolt pieces and then replacing the bolts that hold the ring on the carrier.
If I got the spec on the bolts it would not bother me a bit to just get the replacement if they are the same hardness and dimension from an aftermarket suppllier.
We are in unchartered waters since I have never tried to do a majic trick like that, but you never know until you give it a whirl.
I am talking from experence working on a Wide.
Ned in TN
03-28-2007 09:48:31
 Re: 40T Differential Problem Update in reply to Herny M, 03-27-2007 17:24:04
Henry M
You're right. I know from the manuals I'll have to remove the differentials, I'm just not looking forward to it. I hope the broken screws are the only problem.
Thanks,
Ned in TN
