24 volt generator to 24 volt alternator
Homie
03-27-2007 08:30:28
Can anyone tell me how to hook up a 24 volt alternator on a 4020 John Deere diesel by taking the 24 volt generator off? Putting a 24 volt alternator on from John Deere that went on a 4020 with cab and air conditioner.
Glen in TX
03-27-2007 15:54:09
 Re: 24 volt generator to 24 volt alternator in reply to Homie, 03-27-2007 08:30:28
Motorola 24V with regulator on back I suppose? Not my favorite so not going any farther on hooking up. Check with your JD parts man and see if JD ever offered a conversion wiring harness to do that as it could be available yet. Also check with Agri Services.
buickanddeere
03-27-2007 18:40:40
 Re: 24 volt generator to 24 volt alternator in reply to Glen in TX, 03-27-2007 15:54:09
There is a link to a generator,starter & alternator whiz on the johnnypopper.com site. Ken or Kent is his name. He can build any voltage, any polaity or floating generator/alternator.
Glen in TX
03-28-2007 08:13:28
 Re: 24 volt generator to 24 volt alternator in reply to buickanddeere, 03-27-2007 18:40:40
You mean Kenneth at classicgenerator.com ?? We have a local guy too that can build up a later larger style Delco alternator like used on trucks with transistor box he puts on back of it will put out 12V and 24V for two systems. Sounds like a pain but it still cost less than changing everything on a 6x6 truck with 24V and gives you 12V for accessories without pulling a battery down.
