JD 2555 Hyd oil leak
McRay
03-26-2007 18:35:15
Have JD 2555 that leaking hyd oil where the three point hook up lower bars attach to tractor not sure what the attachment is call. I thinking it has something to do with overload. It leaks with tractor setting. It also is the low point on rear tractor drive axel. How hard is it to reseal the attachment, what all is involved in doing the job.
buickanddeere
03-27-2007 18:43:05
 Re: JD 2555 Hyd oil leak in reply to McRay, 03-26-2007 18:35:15
Isn't there some "wonder glop" additive that makes oil seals swell? It might be worth a shot?
JDknut
03-27-2007 10:04:52
My 2350 MFWD does the same thing. I checked the shop manual and it is a huge job to fix it. You have to tear down the whole affected side of the rear of the tractor, wheel, axle, final drives and all, also pull the top of the final drive case. All to fix a couple of small o-rings and seals. I'm going to hold off as long as I can before biting the bullet. The same repair on a White 2-85 cost $1200 in 1999, this can hardly be cheaper.
Tx Jim
03-27-2007 12:54:38
 Re: JD 2555 Hyd oil leak in reply to JDknut, 03-27-2007 10:04:52
JDknut,what tech manual are you refering to as it only takes about 1(one) hour to renew load and depth control shaft seals on a JD 2555 tractor 2 or FWD if parts,tools and a drain pan are at hand! Tx Jim
Tx Jim
03-27-2007 04:47:18
Name for leak is load & depth control seals. Don't replace bushings unless it's absolutly necessary. Inspect L&D shaft for wear as it takes very little wear to need replacement. Warm seals in warm water or oil to aid installation. Tx Jim
Larry Baker
03-27-2007 02:50:44
thats a pretty common leak
actually i ve got one to fix on my 2755
you need to get seals and bushings and you may also need the bar that runs from side to side
you will need to drain the rear end and pull your arms off
on my tractor i have to pull ne wheel also to get the bar or long pin out
