40T Differential Problem?
Ned in TN
03-26-2007 16:40:51
Pulling a disc and the tractor just stopped. No unusual noise. Engine is running fine, PTO works. It seems to shift into gear okay, with the usual grinding if I shift to quickly. Lifted each rear wheel while running, the left one acted like it was almost trying to move, the right one didn't move and felt stiff when I tried to spin it by hand.
When I put it in gear and applied the brakes hard, it didn't make the engine slow down any.
Any ideas on where to start?
Thanks, Ned in TN
Jason Mills
03-27-2007 05:30:08
 Re: 40T Differential Problem? in reply to Ned in TN, 03-26-2007 16:40:51
I restored my grandfathers '55 40T last year and had to put pinion bearings in it then. They were badly worn, but luckily had not ruined ring and pinion gear. I would suspect this is probably what has happened to yours. Lots of these tractors being parted out and sold at junk yards and ebay. Both final drives will have to be removed for repair if this is the problem. Be careful to properly support tractor during disassembly. Good time for new seals in the final drives, especially the ones on the brake shafts that usually leak and get the brakes wet. Good luck with your project, Jason.
Henry M
03-26-2007 17:26:30
Ned
If it is like a lot of Dubuques, there will be a plate on the rear of the trans just above the pto the same size as the pto.
If so you can remove that cover and shine a flash light in there and see if the pinion is turning and the ring gear is not. You could have dropped a ring and pinion, but that is just a guess.
I base this on the pto still working which means to me that the clutch and input shaft to the trans is turning.
